Телескопы покупают здесь
A A A A Автор Тема: Еще одна Новая в Змееносце!  (Прочитано 6279 раз)
Оффлайн ctacАвтор темы
  • Благодарностей: 257
    • Сообщения от ctac
    • НЦ "Ка-Дар"
« : 21 Мар 2007 [05:04:08] »
 Пока нет ни каких подробностей, буду рад помощи тех, кому доступны циркуляры http://cfa-www.harvard.edu/iau/cbet/RecentCBETs.html ;)
 Стас
Оффлайн Звездный Кот
  • Благодарностей: 15
  • "Отсель грозить мы будем шведу!.."
    • Сообщения от Звездный Кот
Re: Еще одна Новая в Змееносце!
« Ответ #1 : 21 Мар 2007 [05:20:16] »
Есть контакт!
Another apparent nova. This one in Ophiuchus.
                                                Electronic Telegram No. 900
Central Bureau for Astronomical Telegrams
INTERNATIONAL ASTRONOMICAL UNION
M.S. 18, Smithsonian Astrophysical Observatory, Cambridge, MA 02138, U.S.A.
IAUSUBS@CFA.HARVARD.EDU or FAX 617-495-7231 (subscriptions)
CBAT@CFA.HARVARD.EDU (science)
URL http://cfa-www.harvard.edu/iau/cbat.html
APPARENT NOVA IN OPHIUCHUS
     S. Nakano, Sumoto, Japan, reports the discovery by Hideo Nishimura
(Miyawaki, Kakegawa, Shizuoka-ken) of a possible nova (mag 10.2) on two
Kodak T-Max 400 films (limiting mag 12) taken on Mar. 19.812 UT using
a Pentax 6x7 camera (+ 200-mm f/4.0 lens), the new object appearing at
R.A. = 17h42m49s, Decl. = -23o40'07' (equinox 2000.0).  Nothing was
visible at this location on a film taken by Nishimura on Mar. 17.82
and earlier survey films since 2005 (limiting mag 11.5-12).  Nakano adds
that K. Kadota (Ageo, Japan) has confirmed the appearance of the new
star at mag 9.8 on an unfiltered CCD exposure taken on Mar. 20.756 with
a 0.25-m f/5 reflector, the object's position end figures measured to be
44s.00, 35".1; Kadota adds that there is no USNO-A2.0 star within 0'.1
of this position (the closest star having position end figures 43s.41,
34".9 and blue mag 18.5, red mag 16.8).  Also, K. Itagaki has confirmed
the new star using 0.30-cm f/7.8 reflector at his Takanezawa station,
his CCD image on Mar. 20.806 yielding mag 9.7 and position end figures
43s.99, 35".0.
     H. Yamaoka, Kyushu University, reports the apparently independent
discovery of this apparent nova by Yuji Nakamura (Kameyama, Mie, Japan)
at mag 10.0 on unfiltered digital-camera images (cf. CBET 834) taken
on Mar. 20.812 UT.  The variable's position was given by Nakamura as
R.A. = 17h42m44s.5, Decl. -23d40'16" (uncertainty +/- 20"); nothing was
detected at this position on an image taken by Nakamura on Mar. 17.825
(limiting mag about 13.0).  Yamaoka notes that a star of mag 12-13 is
located 1' northeast of the new object.
     Following posting on the Central Bureau's unconfirmed-objects webpage,
H. Naito and S. Narusawa, Nishi-Harima Astronomical Observatory, report
that they obtained a low-resolution spectrogram (range 410-670 nm;
resolution 1500 at H_alpha) of this possible nova on Mar. 20.84 UT with the
2.0-m NAYUTA telescope (+ MALLS).  The spectrum shows Balmer-lines having
P-Cyg features and Fe II lines (multiplets 42, 49, 74), suggesting that the
variable is a "Fe II"-type nova.  The FWHMs of the H_alpha, H_beta, and
H_gamma emissions are 920, 810, and 790 km/s, and the displacement of the
P-Cyg absorptions from the Balmer emission peaks is 940, 820, and 830 km/s,
respectively.
NOTE: These 'Central Bureau Electronic Telegrams' are sometimes
      superseded by text appearing later in the printed IAU Circulars.
                         (C) Copyright 2007 CBAT
2007 March 21                    (CBET 900)               Daniel W. E. Green
Celestron NexStar GPS 11", Meade LX200 GPS 14", Zeiss-600
« Ответ #2 : 21 Мар 2007 [06:04:28] »
Благодаря оперативности Стаса и Майка Симонсена удалось снять область в фильтре V уже на светлом небе. :)
Celestron NexStar 11", CCD Apogee47-Alta.
Экспозиция 5 секунд. Север вверху, восток слева. Поле около 10'
Звездная Новой Vj=10m.2
    • Сообщения от ctac
    • НЦ "Ка-Дар"
« Ответ #3 : 21 Мар 2007 [06:11:41] »
 Все, надо подписываться на рассылку, а то все попращайничать приходится ::) :P Сам бы то же мог бы снять, если бы сразу добрался бы до инфы и если бы не облачность, что то скрывает, то открывает Юпитер :(
 Поздравляю, Макс со скорострельностью! :D
Оффлайн Andrews
    • Сообщения от Andrews
« Ответ #4 : 21 Мар 2007 [08:55:13] »
Стас, IAUC доступен из сети ГАИШ. Сейчас в личку подробности скину.
Оффлайн ilya
  • Благодарностей: 27
    • Сообщения от ilya
« Ответ #5 : 21 Мар 2007 [09:11:06] »
Здорово!Только она будет подниматься у нас чуть выше чем Антараес.Низковато будет. :-\
Оффлайн svv
  • Смотри на Небо и береги Землю!
    • Сообщения от svv
« Ответ #6 : 21 Мар 2007 [12:21:30] »
ОППАНЬКИ!!! :o Новые посыпались как из рога изобилия... -23 гр. это низковато конечно, но попробовать можно. КАРТУ В СТУДИЮ!
... с  уважением, Владимир.
    • Сообщения от ctac
    • НЦ "Ка-Дар"
« Ответ #7 : 21 Мар 2007 [17:40:59] »
 Опуликовал у себя поисковые карты: http://www.ka-dar.ru/forum/index.php/topic,652.msg6252.html#msg6252
 Они крупноваты, но если по ним искать, то промахнуться будет сложно ;)
 Стас
Оффлайн svv
    • Сообщения от svv
« Ответ #8 : 21 Мар 2007 [19:33:16] »
Опуликовал у себя поисковые карты....
Спасибо! Будем искать. М.б. у нас на Юге видно будет. Юпитер - хороший ориентир при таком склонении. Жаль у меня ПК в процессе установки софта и Cartes пока без каталогов.
Оффлайн Pluto
  • Администратор форума
  • Благодарностей: 1086
    • Сообщения от Pluto
« Ответ #9 : 21 Мар 2007 [22:12:27] »
 Стас
Стас, а что мешает здесь карты опубликовать? Или это такая ненавязчивая реклама форума? ;)
    • Сообщения от ctac
    • НЦ "Ка-Дар"
« Ответ #10 : 21 Мар 2007 [22:33:24] »
 Стас
 В том числе и реклама ;) Только вот какой я продукт продаю ???  :)
 Мог бы и тут опубликовать, но я стараюсь не дублировать информацию касательно наблюдений.
Оффлайн Астровитянин
  • Благодарностей: 211
    • Сообщения от Астровитянин
« Ответ #11 : 25 Мар 2007 [21:29:51] »
Как-то все забыли про эту Новую, между тем она сейчас ярче чем звезда в Лебеде, прошедшей ночью - визуальная оценка блеска 9.1m. Визуально звезда выглядит на спектральный класс К. Рядом со звездой прекрасно было видно шаровое звездное скопление NGC6401, блеск которого 9.5m и расположенное в градусе к западу от Новой.
Любопытно, что в апреле 2004г. в этой области, а именно в полуградусе к северу от NGC6401, так же была вспышка Новой. Прям аномальная зона. 8)
B42 <-> D00 <-> L96   300мм Ньютон f/5 + 0.95CC + ZWO294MMpro | 150мм Мак "Интес" |  25х100 бино.
    • Сообщения от ctac
    • НЦ "Ка-Дар"
« Ответ #12 : 25 Мар 2007 [21:57:20] »
Что поделать: склонение в -24гр делают свое дело в северных широтах ::)
 Карта от AAVSO.
« Ответ #13 : 01 Апр 2007 [18:23:41] »
Нова постепенно начала слабеть. Прошедшей ночью ее блеск был 9.6m.
