http://xray.sai.msu.ru/~polar/sci_rev/03_02_24-28.html#astro-ph/0302462Новая статья, специально посвященная интерпретации
Quoth Kopeikin:In this paper we assume that the propagation of light from quasar towards observeralways goes along the electromagnetic null-cone from the past to the future.
Quoth Kopeikin:We emphasize that light from the quasar does not propagatealong the gravity null cone that connects the body (Jupiter, Sun, etc.) and the light particle.Light propagates along the null world line, connecting the quasar and observer, which is nota part of the gravity null cone 2.---------------------------2This might be a reason for the misconceptions presented in (Asada 2002; Will 2003) and discussed by Kopeikin (2003) in more detail
Quoth Kopeikin:Although the value of alpha1 measured from the laser ranging experiments (Muller, Nordtvedt & Vokrouhlicky 1996) and the binary pulsar observations (Bell, Camilo & Damour 1996) gives considerably more stringent limits to alpha1 under assumption that the preferred frame is known, our deflection experiment sets a limit on alpha1 directly without additional assumptions.Further discussion of the results obtained by Will ( 2003) can be found in (Kopeikin 2003b).
AgoraBasta, это русскоязычный форум. Говорите, пожалуйста, по-русски.
This is utter BS! Equation of motion for the photon has to change drastically if cg =/= c.
electromagnetic null-cone propagation must then change the photon's 3momentum even in the flat space
This follows directly from relativistic action eqn...
Хотя и мне по-русски об этом писать труднее...
ЦитатаThis is utter BS! Equation of motion for the photon has to change drastically if cg =/= c.Движение фотона определяется метрическими коэффициентами. Скорость распространения гравитации здесь не причем.Цитатаelectromagnetic null-cone propagation must then change the photon's 3momentum even in the flat space Неверно. Особенно в плоском пространстве.ЦитатаThis follows directly from relativistic action eqn...Действия для чего? Электромагнитного поля в присутствии гравитационного? Нет таких членов там.
...то "c" тут уже есть cg, и ничто иное.
Отсюда всё и следует.
Если cg!=c, то никакого "null cone" нельзя ввести для фотонов. У них нет теперь нулевых геодезических, определяемых ds=0.
Нет. Гравитон может быть массивен. Коли Вы фотон наделили массой...
Но эти "возражения", никак не относятся к обсуждаемой работе. Нигде С. Копейкин не принимал cg!=c.
В вашем воображении это может быть и так.
...Numerical parameter eps=-c/cg, where c is the limiting speed of SR and cg is the 'speed-of-gravity' parameter taking either positive or negative values such that in GR |cg|=c
А если он уже не принимает возможности cg =/= c в своих выкладках, то и вся эта его "экспериментальная" работа в этом направлении и все его громкие заявления ничего уже не стоят, даже номинально.
То что грав потенциал можно считать по Lienard-Wiechert'у - и без Копейкина давно известно.
Очевидно, что Вы невнимательно прочитали работу. ....Это и было ясно, что с помощью ОТО нельзя ввести произвольный параметр, как скорость распространения гравитации. cg = c в ОТО.
И потом, кто "наделил фотон массой"? Уж точно не я...
...In particular, we will assume that light rays move on nullgeodesics of the spacetime metric...
ЦитатаQuoth Kopeikin:In this paper we assume that the propagation of light from quasar towards observeralways goes along the electromagnetic null-cone from the past to the future.This is utter ..! ...
По-русски: "В частности, мы предположим, что свет движется по нулевым геодезическим в метрике пространства-времени". Это, надо заметить, та самая работа, где Уилл получает то самое соотношение, о котором я прошу уважаемого AgoraBasta. .......................С. Копейкин делает такое же предположение. Так что "критика" выше, относится в полной мере и к Уиллу.
1.В первом пункте Ваших "критических замечаний" Вы пытаетесь объяснить, что если cg!=c, то свет движется не по нулевым геодезическим. Теперь мы выяснили, что и Уилл, и Копейкин сделали одно предположение.
Оно здраво физически - постоянство скорости света никто не отменил.
2. Приведенное Вами предположение Копейкина о том, что свет от квазара не распространяется по нулевым геодезическим гравитационного поля объекта Солнечной системы является вполне очевидным.
Если cg!=c, то ОТО не работает.
ЦитатаОно здраво физически - постоянство скорости света никто не отменил. Нет никакого постоянства скорости света в макроскопической области пространства с единой СО в присутствии гравитации.
Я уже три раза вам повторил, что Will и Копейкин сделали разные предположения
..Light propagates along the null world line, connecting the quasar and observer.
Глупости! Пусть тот свет идёт через среду с большим коэфф. преломления, имеем cg>c...
...типа мерим кулоновское поле объекта, изменяемое гравитацией летящей мимо массы
x=cg*t - вот этот 4-х конус ?Если нет, приведите свое определение.
Только интересно, как в плоском пространстве (т.е. отсутствии гравитации), мы должны отталкиваться от cg ?
Неверно. Гамма-квант летит в среде, не в среде, со скоростью c. И для него все остается по-прежнему. То, что Вы говорите - приближение макроэлектродинамики, верное для некоторых средних длин волн,и только для волн - не фотонов. Процесс распространения тех волн посмотрите - внутри вещества, микроскопически, действует тот же Максвелл с с.
Легко. Объект с зарядом Q на расстоянии r имеет тестовый объект с зарядом q. Измеряю силу F=Q*q/r**2. Пролетает "мимо" ЧД массы M на расстоянии rho >> r. По-Вашему, измеряю я уже не F, а F'. Формулку для F' дайте.
Хотите использовать КЭД - используйте, но не забудьте потом интерпретировать результаты обратно в макроскопические понятия.
А какой смысл имеет "расстояние r" в вашем примере? А заряд/наблюдатель как-нибудь движутся? И вообще СО определите , для начала...
Гравитация - это метрика, т.е. в плоском пространстве она всего-лишь постоянна, а не отсутствует
Таким образом, всё копейкинское достижение, в лучшем случае, эквивалентно расчёту движения частиц с ненулевой массой в поле движущегося тела.
Так что простой контрпример с гамма-квантом разрушает Вашу идею.
