Только что обновил с 2.75 до 2.76 версию Картеса, но ситуация координально не изменилась, да теперь если элементы от СВТА, то они верны, а вот astrob.dat все так же врет А в нем намного больше астероидов, чем в СВТА!!! Стас
JPL/HORIZONS 4 Vesta 2006-Jul-16 02:58:59Rec #: 4 (+COV) Soln.date: 2005-Apr-22_14:19:35 # obs: 6409 (1827-2004) FK5/J2000.0 helio. ecliptic osc. elements (AU, DAYS, DEG, period=Julian yrs): EPOCH= 2444686.5 ! 1981-Mar-23.00 (CT) Residual RMS= .4411 EC= 0.08972689062498941 QR= 2.149895937055027 TP= 2444990.438069798 OM= 104.124211017328 W= 150.2295814692592 IN= 7.140226359613001 A= 2.361814179626965 MA= 277.4683388333326 ADIST= 2.573732422198903 PER= 3.62975 N= .271541045 ANGMOM= .026329887 DAN= 2.54068 DDN= 2.17352 L= 254.5456643 B= 3.5383864 TP= 1982-Jan-20.9380698 Physical parameters (KM, SEC, rotational period in hours): GM= 17.8 RAD= 265. ROTPER= 5.342 H= 3.2 G= .320 B-V= .782 ALBEDO= .4228 STYP= V ASTEROID comments: 1: soln ref.= JPL#27, OCC=02: source=ORB*******************************************************************************
(4) Vesta mag 8.2Period of orbit 3.63 years (1325.3 days)Perihelion distance 2.15 AUAphelion distance 2.57 AUOrbital elements: Semimajor axis 2.3613049 AU Eccentricity 0.0890880 Inclination of orbit 7.1335000 degrees Argument of perihelion 150.3093000 degrees Long. ascending node 103.9261000 degrees Mean anomaly 232.8049000 degrees Epoch of elements JD 2453800.5 ( 6 Mar 2006 0:00)Right ascension: 09h10m20.964sDeclination: +20 17' 31.15"Mean position at current epoch:Right ascension: 09h10m43.090sDeclination: +20 15' 55.00"Apparent position at current epoch:Right ascension: 09h10m42.207sDeclination: +20 16' 06.14"Dist from home planet: 3.14723222 AU (470,819,237 km)Heliocentric position: lon 148.35812 lat 5.00708Heliocentric radius 2.40027 AU98.43% illuminatedPhase angle: 14.41 degreesElongation from Sun 36.00 degrees (evening sky)Speed of apparent motion: 1.091'/hour at position angle 106.0
Vesta mag 8.2Right ascension: 09h10m20.960sDeclination: +20 17' 31.19"Mean position at current epoch:Right ascension: 09h10m43.087sDeclination: +20 15' 55.03"Apparent position at current epoch:Right ascension: 09h10m42.204sDeclination: +20 16' 06.18"Dist from home planet: 3.14723273 AU (470,819,313 km)Heliocentric position: lon 148.35810 lat 5.00708Heliocentric radius 2.40027 AU98.43% illuminatedPhase angle: 14.41 degreesElongation from Sun 36.00 degrees (evening sky)Speed of apparent motion: 1.091'/hour at position angle 106.0Asteroid diameter 501. -+24. km 0.22 arcseconds angular diameterAlbedo .38 -+.03Rotation period 5.342 hours(Very secure result; a pole position has been reported.)Magnitude varies by 0.12Absolute magnitude: 3.20Slope parameter: 0.32Color index (B-V): 0.80IRAS taxonomic class: rOrbital arc: 63488 days6007 observations made to determine orbitOrbit computed on 06 11 2001Current ephemeris uncertainty (CEU) on 30 11 2001: 1.9E-02 arcseconds, changing by 7.2E-07 arcseconds/dayNext peak CEU: 1.9E-02 arcsec, on 01 12 2001Maximum CEU in next ten years: 3.1E-02 arcsec, on 07 06 2007Comments from the MPCORB database:Designation: (4)VestaAbsolute magnitude: 3.20Slope parameter: 0.32Orbital elements: Semimajor axis: 2.3613051 Eccentricity: 0.0890882 Inclination of orbit: 7.13351 Argument of perihelion: 150.30933 Long. ascending node: 103.92607 Mean anomaly: 232.80490 Mean daily motion: 0.27162887 degrees/day Epoch of elements: 6 Mar 20065168 observations made at 56 oppositionsOrbital arc: 1841-1993Last observed: 1993 00 00RMS residual: 0.56Perturbing objects used in orbit: M-cOrbit computed by BowellReference: MPC 24219
Ничего себе, больше чем на минуту врет! Не должен. Даже StarCalc намного точней.
Кстати, а вы сравнивали СтарКальк с НАСАвским калькулятором? Откуда такая уверенность? Стас
2001 HN36 2006 09 22.0 54.7305 2.712244 0.084875 22.6238 233.5234 31.0703 14.6 0.15
А RedShift5 из какого формата файла элементов орбиты берет для астероидов орбиты?
