Телескопы покупают здесь
A A A A Автор Тема: Вышел Xephem 3.7  (Прочитано 2597 раз)
Оффлайн елVIсАвтор темы
  • Благодарностей: 15
    • Сообщения от елVIс
Вышел Xephem 3.7
« : 30 Авг 2005 [19:16:46] »
Вышел Xephem 3.7  http://www.clearskyinstitute.com/xephem/index.html
Довольно много изменений (теперь поддерживается PNG, улучшен скроллинг карт),
кроме того добавлена штатно поддержка OpenVMS (VAX, Alpha, Itanium) стараниями вашего покорного слуги :)
Changes from 3.6.4 to 3.7
Released August 1, 2005
    New Features:
        * Data
              o Includes Hubble GSC 2.2.0.1 catalog, 450 million stars complete to M18.5.
              o New and updated catalogs: Messier, IC, NGC, COVBS, SKY2000, HYPERLEDA, Supernova, WDSC, Open clusters, Henry-Draper, Pleiades and asteroids.
              o YBS replaced with Sky 2000 to magnitude 6.5.
              o Can now display Gallery image directly from Data Index.
        * Earth View
              o Display satellite orbits in space.
              o Zoom in to see better geography, or out to see high orbits.
              o Quick-set button to set equator rotation.
              o Display of surface footprint is now optional.
              o Expanded range mouse panning allows continuous rotation.
        * Sky View
              o Save and restore sets of eyepiece definitions.
              o Save and restore sets of eyepiece Sky positions.
              o Constellation figure definitions now stored in editable files.
              o WCS solver invoked automatically if header has seed but no solution.
              o Shortcut button to set display aspect ratio to match image.
              o FITS file blinking via new Movie frame function.
        * User Annotation
              o Anchor locations are now based on the view's world coordinates.
              o Sets of annotations may be saved and loaded from files.
        * Other
              o Collect any number of View, NAAG or Plot frames into a movie, save as set of PNG files.
              o Many tweaks for improved INDI support, including display FITS BLOBs.
    Bugs fixed:
        * Negative years in some date formats.
        * WCS solver could result in RA outside range 0..24 hours.
        * Setting lat or long would reset elevation.
        * Highly zoomed FITS images would show half-pixel offset.
        * FITS images without WCS headers could generate bogus graphic overlays.
        * Sky View compass rose rotation angle could be wrong near poles.
        * Persistent labels on Earth trails in Sol System view were incorrect.
        * Outdated magnetic declination model updated.
ТАЛ-150ПМ, Coronado PST, Алькор, Pentax IstD с ЗМ-5СА и МТО-1000
Оффлайн DosEclipsesTotales
  • Благодарностей: 35
  • Mi casa es la Vía Láctea
    • Сообщения от DosEclipsesTotales
Re: Вышел Xephem 3.7
« Ответ #1 : 31 Авг 2005 [13:27:08] »
Хорошая новость, спасибо. Надо посмотреть.
Оффтоп. Есть у меня free shell в кластере с OpenVMS, может, мне его туда поставить? ))
evgenyg
« Ответ #2 : 31 Авг 2005 [14:10:16] »
Версия 3.7 не кoмпилируется нa Федoрa 3. Make не нaхoдит фaилы, хoтя oни есть в директoриях 3.7
« Ответ #3 : 31 Авг 2005 [14:22:02] »
Посмотрим, как будет компилироваться на моих ASP9 и FBSD 4.9 и 5.3. Закачать бы еще сначала
« Ответ #4 : 31 Авг 2005 [15:14:21] »
2 МОНАХ:
Хорошее дело -юзать правильные проги под правильными операционками  :)  если будете ставить - пишите.  :)
Кстати, у Вас на чем? Alpha, VAX или Itanium? Хотелось бы и мне получить шелл на Itaniume.
У кого не получилось собрать на федоре под X86 собирали  вот так:
make MOTIF=../../libXm/linux86
У меня собралось.  Можно и по другому.
Под Федорой на Альфе, например, надо поставить вначале lesstiff, потом сказать
xmkmf -a
make
« Последнее редактирование: 31 Авг 2005 [15:18:01] от елVIс »
evgenyg
« Ответ #5 : 31 Авг 2005 [16:21:17] »
Рaспaкoвывaю и делaю "cd" кaк нaписaнo в инструкции и зaтем
In file included from aavso.c:12: ../../libXm/linux86/Xm/Xm.h:59:34: X11/extensions/Print.h: No such file or directory
In file included from aavso.c:12: ../../libXm/linux86/Xm/Xm.h:755: error: syntax error before "XPContext"
../../libXm/linux86/Xm/Xm.h:755: warning: no semicolon at end of struct or union
../../libXm/linux86/Xm/Xm.h:758: error: syntax error before '}' token
../../libXm/linux86/Xm/Xm.h:758: warning: type defaults to `int' in declaration of`XmPrintShellCallbackStruct'
../../libXm/linux86/Xm/Xm.h:758: warning: data definition has no type or storage class
make: *** [aavso.o] Error 1
« Ответ #6 : 31 Авг 2005 [17:38:47] »
У меня в ASP собралось все без проблем. Я юзал и поставляемые либы и хэдеры Motif (make MOTIF=../../libXm/linux86), так и имеющиеся у меня в системе (make MOTIF=/usr/X11R6/lib). В обоих случаях ошибок не выдавало, и Xephem работал без сбоев.
ЗЫ. А то, что Xephem с полтыка скачивает фото через наш парольный squid, меня очень и очень порадовало. Полюбовался на свежие изображения нашего дневного светила в разных диапазонах давненько не приходилось.
Vladimir Sh.
« Ответ #7 : 31 Авг 2005 [17:45:30] »
На Fedora 2  всё встало отлично. Так что, надо искать где-то в обновлениях F2->F3
« Ответ #8 : 31 Авг 2005 [18:59:40] »
Ключевая фраза здесь -  X11/extensions/Print.h: No such file or directory
Посмотри у себя - в  /usr/X11R6/include/X11/extensions
Если точно его нет, значит чего-то не доставил.
Грязный фикс - возьми мой и скопируй в   /usr/X11R6/include/X11/extension
« Ответ #9 : 01 Сен 2005 [06:48:22] »
Или поставить XFree86-devel-*.rpm
« Ответ #10 : 01 Сен 2005 [08:51:43] »
Тогда уж Xorg-devel-*.rpm   ;D
evgenyg
« Ответ #11 : 01 Сен 2005 [10:49:42] »
Я пoстaвил openmotif-devel и xephem oткoмпилирoвaлся.
Нo есть другaя прoблемa. Если я пытaюсь oткрыть View -> SkyView, тo xephem пaдaет и печaтaет в кoнсoли
can not find classicfigs.csf
Aborted
Кaк пoчинить?
« Ответ #12 : 01 Сен 2005 [15:02:20] »
Интересно. У меня нигде такого не было.
Сейчас посмотрим.
BTW напиши команды, какими собирал.
Запускаешь xephem из каталога gui ?
« Ответ #13 : 01 Сен 2005 [15:06:28] »
Такое случается, если не запускаешь из каталога gui/xephem
Зайди в auxil и посмотри, есть ли этот файл в наличии.
